Activity Forums Apple Final Cut Pro Legacy FCP 5 capturing audio only…. WO’T CAPTURE VIDEO
  • FCP 5 capturing audio only…. WO’T CAPTURE VIDEO
    Posted by Stephen Hill on January 30, 2009 at 8:45 pm
    In the last 2 days FCP has quit seeing the video stream from my DV deck. It will capture the audio, and I can control the deck, but FCP won’t see the video stream. I Movie will see and capture everything correctly, but FCP 5 won’t. I have tried the following. —
    replacing cables, replacing decks, restarting the software, restarting the machine, trashing prefs, swapping users… swapping machines fixed the problem, and so did using I Movie — those two methods confirmed there is a problem w/ FCP software.
    nothing fixes the problem… HELP ME!!!! I need to capture these tapes.
    Rafael Amador replied 17 years, 7 months ago 3 Members · 2 Replies
  • Jeffrey Reiber
    January 30, 2009 at 10:39 pm
    The best way I can think of is to look in the help menu or maybe call apple, might be an issue with your computer or software
  • Rafael Amador
    January 31, 2009 at 2:08 am
    By any chance have you unchecked “Video” in the “Clip Setting” window of the “Log and Capture”.If so, you will only record Audio.
    Rafael
    http://www.nagavideo.com
