Activity Forums AJA Video Systems FCP 5 capture stopping early.
  • FCP 5 capture stopping early.
    Posted by Bill Portune on May 26, 2005 at 11:31 am
    Trying to digitize 55:00 show, but the capture keeps stopping at around 49:00. It doesn’t abort; FCP/Kona2 thinks it’s done, but the capture is short. I’ve tried this a few times and it’s pretty consistent – any body have any ideas before I start calling folks?
    Bill Portune
    The Chesapeake Group
    G5 DP 2G, 10.3.9, QT 7, 1.5GB RAM, FCP 5.0, Io, Kona2(1.1.1), UL4D, Huge U320R
    Bill Portune replied 21 years, 3 months ago 5 Members · 6 Replies
  • Sean O’connell
    May 26, 2005 at 1:11 pm
    maybe you’ve reached a maximum file size??
    sean oconnell
    oconnellsean@comcast.net
  • Jared Picune
    May 26, 2005 at 1:20 pm
    You might have a timecode break and FCP is calculating the duration as 49 instead of 55. I have had this happen to me in 4.5.
    Jared
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
  • Bill Portune
    May 26, 2005 at 1:46 pm
    Happened on 2 seperate masters on 2 different machines, so I’m confident it isn’t a time code break.
    The Video file is 19.94 Gigs, and audio is 894 Megs, so possibly it could be a file limit to 20 Gigs. I can’t find anything in FCP 5 that limits overall file size – I wonder if it could be a QT7 issue?
  • Greg Jones
    May 27, 2005 at 11:19 am
    I always digitize in smaller chunks. Try batch capturing your clip in 10 to 15minute segments.
    Greg Jones
    D7,Inc.
    Orlando,Fl.
  • Ron Thompson
    May 29, 2005 at 5:44 pm
    [Bill Portune] “The Video file is 19.94 Gigs, and audio is 894 Megs”
    Are capturing A/V separately?
    Sounds like that could be a part of the problem.
  • Bill Portune
    May 31, 2005 at 4:15 pm
    Thank’s Ron, that was indeed the problem!
    I’ve been capturing A/V separately so that when I use MediaManager to trim down my media the A files don’t end up with V at the same time…
