FCP 4.5HD Audio Aligning Issue – PLEASE HELP!!
I will be detailed as possible as to hopefully find a solution to this extremely frustrating issue.
System:
OSX 10.3.9
FCP 4.5 HD
Compressor 1.2.1
QuickTime Various version (7.0.3 – 6.5.2)
Video imported as 16:9 from Sony VX2000I filmed a wedding. Imported all the footage into one FCP session. I edited everything and exported using Compressor. Every thing exported fine EXCEPT one section. Section is about 25 minutes long has a music file at the front that was recorded at 16 bit 44.1 (session is at 48k – which may be a problem – but it plays just fine in session) – has a LiveType file in front and then other than that just audio that was recorded off the camera mic a few transisions and then fade out. Simple file actually. When I play it in FCP the audio sync’s up all the way through the entire section with out issues. At first when I exported it using Compressor the audio would start about 6 seconds after it was suppose to. Now mind you ALL the other files exported without error! I tried exporting it about 4 times still the same result. I tried to export it as a QuickTime file but I had problems and then when I did get it to work it looked crappy – some dropped frames and when panning it was jittery. Audio was in sync though.
So into work around mode: I opened a new session imported the video of just that section that I needed and basically recreating what I had already done. I exported still the same problem. So I took the FCP files and went to another Mac same OS new install of FCP and Compressor updated and Disc Utility and Mac Warrior before doing anything QuickTIme here was 7.0.3 also…export now the audio starts out ok but slowly over the entire piece it grows late. Crap! So I go to another laptop same OS new install ect except QuickTime 6.5.2 export same thing starts fine slowing grows late – CRAP!
I have put about 25 to 30 hours into this and I am about feed up. I don’t understand why all the other files would export fine and this one won’t – that is the biggest thing I don’t understand. I had 16 bit 44.1 audio in some of those too and they are fine so I can’t imagine that be the issue. Settings/Preferences didn’t change in the first master session.
I really need to get this thing done – already 3 weeks late to client and only this one little section is the hold up. Any input will be appreciated. BTW, I have some working knowledge but please if you are giving suggestions make sure a novice can understand them – that would help me out a lot.
Thanks in advance.
