Activity Forums Apple Final Cut Pro Legacy FCP 4.5/5.0 Colorbar BUG – MYSTERY
  • FCP 4.5/5.0 Colorbar BUG – MYSTERY
    Posted by Mactavish on June 23, 2005 at 5:02 pm
    6-23-05
    Can anyone confirm “odd” behavior in FCP 4.5, also seen by a friend in FCP 5.
    1) Using a straight forward new DV-NTSC project. In FCP
    Invalid User replied 21 years, 3 months ago 3 Members · 2 Replies
  • Todd Beabout
    June 23, 2005 at 8:46 pm
    I think this is because from your viewer you are looking at uncompressed bars. When you look at them in a DV sequence you are looking at them through DV compression, and I believe that DV adds setup (affects your black levels).
    -Todd Beabout
    Vazda Studios
  • Invalid User
    June 23, 2005 at 9:25 pm
    Not quite, this is not an IRE issue or it would effect the entire colorbar range. Believe me, I am well schooled on 0-7.5 IRE and DV issues. Read my post again, it ONLY effects TWO color squares. Did you do the test?
