Activity › Forums › Apple Final Cut Pro Legacy › FCP 4.5 Pro
FCP 4.5 Pro
Posted by Nanuk on May 19, 2005 at 10:17 amHi, does anybody know, if it is possible to put a letterbox over your playout while outputting a seq without rendering?
Thx Nanuk
Jerry Hofmann replied 21 years, 3 months ago 2 Members · 3 Replies -
Jerry Hofmann
May 19, 2005 at 12:09 pmWould depend on your CPU’s speed, but the widescreen filter, or cropping the images can be real time. I’d think any dual G5 with fast enough disk drives should handle it in DV or uncompressed SD.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Nanuk
May 19, 2005 at 12:14 pmI have to do a HD output. Uncompressed!
I got a dual G5 with an XRAID behind it. Do you think that will work -
Jerry Hofmann
May 19, 2005 at 12:21 pmSure with the addition of a capture card in the G5 you can do this… Kona 2 would be my recommendation for this.
Jerry
