Activity Forums Apple Final Cut Pro Legacy FCP 4.5 – Layering Video Clips
  • FCP 4.5 – Layering Video Clips
    Posted by Charlie Bluehawk on March 19, 2009 at 3:04 am
    Hello,
    I am using FCP 4.5 on my old G3.
    I have a very basic, silly problem.
    I have three video clips, each on its own track, and for some reason, the alpha is not working. The video clip on the top track is blocking out the lower two video clips.
    Help!!!! Thanks!
    Charlie Bluehawk replied 17 years, 6 months ago 2 Members · 2 Replies
  • Dino Vince
    March 19, 2009 at 12:44 pm
    not sure how you made your alpha or in what application….you could try going into the ‘Modify’ menu and changing up the alpha settings…see if that helps. If not, provide more info and I’ll try to check back. Good luck.
  • Charlie Bluehawk
    March 19, 2009 at 11:17 pm
    Hi!
    Thanks for getting back to me.
    Turns out that what I did was I selected “darken” (under “composite mode”) and thus made the alpha “black”!!!
    (Its been awhile since I used FCP and I am way out of practice!)
    Now I am trying to remember how to “break” (or separate) the video and audio tracks in a single clip from each other. I have many layers of clips I am working with, and I have no use for most of the audio tracks.
    Thanks again! Charlie.
