Activity Forums Adobe After Effects fcp 4.5 imports used to not have jaggies-now FCP5 JAGGIES
  • fcp 4.5 imports used to not have jaggies-now FCP5 JAGGIES
    Posted by Todd Reid on February 23, 2006 at 7:34 pm
    I don’t know much about after effects, so be nice. Our art director has a VAST knowledge, but can’t figure this out.
    I’d like to impress him, please help!
    The art director at the company I work for used to do all the chroma keying for our final cut pro systems. We would strip off all effects, then export clips for him to create key & alpha, send it through QT pro (QT pro may have been the next step after fcp, all this was done before I joined) then import back to fcp and viola crystal clear keys every time. Now that fcp and quicktime has been updated, we get jagged edges no matter what we do. I have solved our chroma key problem with zmatte for fcp, but now anytime we try to export ANYTHING to AE, it adds severe jagged edges. We use DV50 codec, but don’t blame that, cause it used to work perfectly, so its not the codec.
    The work around we’ve been using is to have a dual boot that allows us to run our older versions of QT & fcp. Works like a champ, however as you may imagine that a big huge pain in the butt and we need a much more productive solution.
    Current working example…I’m working on an ID tag where our talent knocks on the inside of the tv screen and says “pay attention”. I wanted to add a little bulge and lighting effect where he is knocking. I composited the talent (blue screen) over a moving background, then exported to AE. I created the bulge and lighting effect and I was pretty happy with it and it looked good (no jaggies) in AE, then exported as animation codec. Import into fcp and JAGGIES.
    Comments, theories or suggestions appreciated.
    What am I missing?
    Todd Reid replied 20 years, 6 months ago 6,942 Members · 1 Reply
  • Todd Reid
    February 24, 2006 at 3:06 pm
    I’m confused too.
    I’m not exactly sure where the stairstepping is being introduced, that is why I sought the cow.
    fcp forum thinks its the compressed codec, but I don’t want to use that as a crutch, since I’ve seen crystal clear keys with dv50 codec.
    I was thinking it was QT. Maybe I’ll downgrade a version or 2 and see what results I get.
    I was hoping someone else had run into this and could shed some light.
    Unfortunately, like most people, we’re so busy, that we don’t have much time to troubleshoot.
    Thanks for your thoughts.
