Activity › Forums › Apple Final Cut Pro Legacy › FCP 4.5 Help
  • Posted by Chee Keong hiu on June 10, 2005 at 1:41 am
    Help,thank you
    1. Logging Capture No Audio – When I logging viewing clip in ‘Log & Capture’ windows, I can’t hear the audio through speaker, even though there’s audio volume showing in the audio
    meter.
    I understand that during capture we won’t hear any audio, but why during
    logging clip also no audio, but the audio is in after capture view back. Any ideas ?
    2. In FCP export – Quicktime Converter, how can I set up my own customer setting. Can’t find any save setting button. What I want to do is, take the 3GP default setting and twist some setting inside then save it as my own customer setting. Any solution ?
    3. View source timecode – say i use the match frame to find the source clip in view windows, how can i check the actual source timecode of that frame ?
    ckeong
    Jerry Hofmann replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 10, 2005 at 4:29 pm
    Duplicate the capture preset you are using now, and in the editor window that opens click on the advanced button in the audio area of the window, turn the speakers to on and use this instead of the stock preset.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
