Activity › Forums › Apple Final Cut Pro Legacy › FCP 4.5 HD network performance…..
Posted by Trey Eckles on May 10, 2005 at 4:11 pmI have a G5 1.6 PowerBook 1.25 and thinking about getting a mac mini. If I network these 3 cpu would these cpu’s increase FCP’s performance?
Kevin Monahan replied 21 years, 4 months ago 4 Members · 6 Replies -
Todd Beabout
May 10, 2005 at 4:17 pmNo. What kind of performance issues are you having?
-Todd Beabout
Vazda Studios -
Peter
May 10, 2005 at 4:41 pmit will in fcp 5 they say. But the fastest one they make still is not fast enough, so I don’t know if a mini will do much good. Just my thought
Kevin Monahan
May 10, 2005 at 5:10 pmWhat on earth are you guys talking about? Network rendering for FCP? FCP 5 won’t do that, but Compressor will do distributed encoding. Is that what you mean?
Kevin Monahan
Author – Motion Graphics and Effects in Final Cut Pro
fcpworld.com -
Todd Beabout
May 10, 2005 at 5:15 pmHeh, even if it did network render that doesn’t really have to do with performance… That’s why I asked what his performance issues were. I don’t know about you guys, but network rendering isn’t something that I would even really use in my workflow. FCP is rendering what I give it so fast these days I can barely get in the occasional cigarette!
-Todd Beabout
Vazda Studios -
Trey Eckles
May 10, 2005 at 5:27 pmI just wanted to speed up my rendering time and add more real time playback options.
Kevin Monahan
May 10, 2005 at 5:35 pmA network setup won’t buy you much in those regards. If you want more RT, then buy the fastest Mac you can afford. You want better performance? Stuff it full of RAM and buy the fastest drives you can get. An Xserve RAID is pretty awesome.
A networked setup with Xsan or the like buys you media sharing capabilities and distributed encoding for Compressor. You can do distributed rendering with Shake, too.
You don’t need Xsan for the distributed encoding for compressor or rendering for Shake. Gigabit ethernet will do–but you won’t get reliable media share capabilities.
Kevin Monahan
fcpworld.com
