Activity › Forums › Apple Final Cut Pro Legacy › FCP 4.5 doesn’t recognize camera
  • FCP 4.5 doesn’t recognize camera
    Posted by John1977 on August 14, 2006 at 6:36 am
    Hmmm….. Here a question once again. In the other topic I asked about how to reinstall FCP 4.5.
    Actually I installed FCP 5 because all of a sudden my configuration doesn’t recognize my camera (a sony VX2000) anymore.
    After installing 4.5 once again, the problem still exists, so it’s not the program I guess. Strange thing: in my log & capture I can still control my cam but I have no image! FCP says that the firewire pal device is missing…
    I’ve been working with FCP since version 1.2 and I’ve never had any trouble with this… I thought FCP 4.5 has always been compatible with my camera. It used to work prefect. That’s also the info apple gives on their site.
    Does anybody have any idea or the same experience? Could it simply be my firewire cable or is it FCP related? I can’t figure it out here : (
    Some system specifications:
    I’m working on an old G4 (dual 450 mhz) with FCP 4.5 and a Sony VX2000
    Thanks once again!
    Don Greening replied 20 years, 1 month ago 2 Members · 1 Reply
  • Don Greening
    August 14, 2006 at 5:56 pm
    [john1977] “Could it simply be my firewire cable or is it FCP related?”
    It’s probbly Quicktime related. If you’re using Quicktime 7 try this:
    https://docs.info.apple.com/article.html?artnum=301852
    If you’re back using FCP 4.5 then you should really be using Quicktime 6.5.2 with it as they’re more compatible.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
