Activity Forums Apple Final Cut Pro Legacy FCP 4.5 capturing PAL problem
  • FCP 4.5 capturing PAL problem
    Posted by Donjany on July 21, 2005 at 6:55 am
    Hi everybody,
    I’m using powerbookG4 1.25 ghz with 15GB free space and sony vx 2100E ( pal version)
    After capturing the video looks like is missing every third frame or it doesn’t look smooth. In “imovie” it looks perfect.
    My FCP audio/video settings are:
    sequence presets= DVPAL 48khz
    Frame Size: 720 x 576 Pixels
    Editing Timebase: 25 fps
    Field Dominance: Lower (Even)
    Pixel Aspect Ratio: PAL – CCIR 601
    Anamorphic 16:9: Off
    Video Processing: YUV allowed (8-bit)
    White Point: White
    Compressor: DV – PAL
    Millions of Colors (24 bit)
    No Data Rate Limit
    No Keyframes Set
    Quality: 100
    Audio Settings:
    16-bit 48.000 kHz Stereo
    capture presets= DV PAL 48khz
    Using DV Video for video input
    Canon DV using PAL
    25 frames per second
    DV – PAL at Best quality.
    24 bits per pixel
    720 by 576
    Using DV Audio for audio input
    Input: First 2 channels
    Rate: 48.000 kHz
    Speaker: off
    Volume: 100, Gain: 0
    device control preset= FireWire PAL
    Protocol: Apple FireWire
    Time Source: DV Time
    Frame Rate: 25
    Use Non-Drop frame timecode by default
    Do not use deck search mechansism
    Pre-roll: 3 seconds
    Post-roll: 3 seconds
    Capture Offset: 0.000 frames
    Handle Size: 00:00:00:00
    Playback Offset: 00:00:00:00
    a/v devices
    video= apple fw PAL (720×576)
    audio=fw DV
    What I’m doing wrong? There are nobody to help me
    out…so if you know the solution or any help will be
    apriciate.
    Thank you for your time and I hope to hear from you
    soon.
    Sincerely
    donJANY.
    donJANY
    David Scott replied 21 years, 2 months ago 2 Members · 1 Reply
  • David Scott
    July 22, 2005 at 9:46 am
    It sounds like a field issue although your setting seem correct. It my be worth changing your fields from “even” to “odd” as a test (although for DV it should be “even”).
    Are you viewing it on an output monitor or simply the computer, as to clearly see field issues it needs to be a TV monitor.
    Cheers
    David Scott
