Activity Forums Apple Final Cut Pro Legacy FCP 4.5 AGP error
  • FCP 4.5 AGP error
    Posted by Kari on August 9, 2006 at 9:25 pm
    Hello. I have a Power Mac G5 with FCP 4.5 installed. When I launch FCP the following error appears: “no specific AGP card is missing” Is FCP not compatible with my display? Display works fine with other aps. Should I upgrade to 5 to fix the problem? Here are the specs of my machine: (I am sure I am writing more than one might need to diagnose)
    Machine Model: PowerMac 11,2
    CPU Type: PowerPC G5 (1.1)
    Number of CPUs: 2
    CPU Speed: 2.3GHz
    L2 Cache (per CPU): 1MB
    Memory: 1.5GB
    Bus Speed: 1.15GHz
    Boot ROM Version: 5.2.7f1
    Graphic Display info:
    NVIDA GeForce 6600:
    Chipset Model: GeForce 6600
    Type: Display
    Bus: PCI
    Slot: SLOT-1
    BRAM (Total): 256MB
    Vendor: nVIDIA (0x10de)
    Apple Cinema HD Display:
    Display Type: LCD
    Resolution 1920×1200
    Depth: 32 bit color
    Core Image: Supported
    Main Display: Yes
    Mirror: off
    Quartz Extreme: Supported
    Thanks for you help.
    Best
    Kari
    Richard Harrington replied 20 years, 1 month ago 2 Members · 1 Reply
  • Richard Harrington
    August 10, 2006 at 5:37 pm
    I’d run system test…. from your isntall disc.. but that configuration shoudl work (you didn’t remiove factory installed card did you?)
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
