Activity Forums Apple Final Cut Pro Legacy FCP 4 Dropped Frame Issue
  • FCP 4 Dropped Frame Issue
    Posted by Jumperman06 on June 8, 2007 at 2:46 pm
    I’m trying to log and capture footage onto my iMac G5 Final Cut Pro 4 program –
    I can see the video playback in the LOG AND CAPTURE window, and I see it again when i hit “NOW” to capture the clip – however, between 15-30 seconds later (each time) the following message pops up on my screen:
    “Dropped frames were detected during the last capture attempt”
    This happens every time – I’ve tried playback from my SONY DV Camera as well as my SONY GV-D200 8mm/HI-8 playback deck – same problem on both. No glitches on the tapes –
    Please, how can I solve this issue? – is there a setting I need to adjust on Final Cut?
    Ben
    Jumperman06 replied 19 years, 2 months ago 3 Members · 4 Replies
  • David Roth weiss
    June 8, 2007 at 3:08 pm
    This typically happens when one is capturing to their system drive, either by accident or because they did not know better. Is that what you’re doing?
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Ben Insler
    June 8, 2007 at 3:13 pm
    This will also happen if you’re capturing to a drive that is too slow to keep up with the necessary data rate that is required to stream your media for capture. You should be using at least a 7200 RPM 8MB Cache Firewire 400 drive.
  • Jumperman06
    June 8, 2007 at 8:42 pm
    How exactly do I do all that? I’ve also received a message that says my scratch disk is almost full – i guess i’m not as Mac-savvy as I thought – please help – I don’t even know where to adjust the drive for 7200 RPM etc…
  • Jumperman06
    June 8, 2007 at 8:43 pm
    Yep, I guess I didn’t know better – how can I fix this?
