Activity › Forums › Apple Final Cut Pro Legacy › FCP 4 and realtime HD !?!
  • FCP 4 and realtime HD !?!
    Posted by Ndamir on April 20, 2005 at 8:47 am
    I have G5/2.0DP, 4GB RAM, xServe RAID and BlackMagic HD card.
    If I put 1 stream of HD video in my sequence everything is OK no rendering required. But if I apply transition or filter I need to render. Not one filter or transition in FCP is bolded (realtime) while I work with HD material.
    I tried FCP rendering engine and BlackMagic rendering engine with no luck.
    Is this normal!?!
    Thanks in advance!
    Damir Nazor
    Ndamir replied 21 years, 5 months ago 2 Members · 2 Replies
  • Tom Wolsky
    April 20, 2005 at 11:57 am
    What type of HD is it and what RT settings are you using?
  • Ndamir
    April 20, 2005 at 12:57 pm
    Uncompressed 10-bit HD
    I tried FCP rendering engine and BlackMagic rendering engine with same result.
    What I would like to know is can FCP render effects in real time on HD stream and if it can how (settings)?
    Damir
