Activity Forums Apple Final Cut Pro Legacy FCP 2997 fps to 23.98 fps
  • FCP 2997 fps to 23.98 fps
    Posted by Marc Fisher on October 24, 2006 at 8:26 pm
    We have a client who, for some unknown reason, thought they should edit in 29.97 instead of 23.98, For HD online. is there a way in FCP to convert the sequence from the Offline station to the Online, other than using Cinema tools to convert the frame rate? XML perhaps?
    thanks.
    Marc
    Marc Fisher replied 19 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    October 24, 2006 at 8:52 pm
    Sorry, only CT can convert the 29.97 EDL to 23.98. it is really easy…do you not have CT? Why are you against it?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Marc Fisher
    October 24, 2006 at 9:27 pm
    I’m not against it, i just would’ve l;iked a better conform process than using an EDL. isn’t that what we’re all hoping for? EDL’s are fine as long as you stick to cuts and dissolves, but once more effects are included, an XML, or AAF type file is much better.
    thanks for the info however, I’ll p[ost my findings.
