Activity Forums Apple Final Cut Pro Legacy FCP 2 frame Transition Glitch
  • FCP 2 frame Transition Glitch
    Posted by Adam Welch on July 17, 2011 at 1:10 am
    I’ve recently been utilizing canon dslr’s and transcoding h264 footage into prores 422 for my work in event videography.
    This week, I’ve been having an issue whereby fcp repeats the last two frames of each transition, AFTER the transition. Here’s an example clip I have posted:
    https://www.vimeo.com/25875539
    I had initially thought it was isolated to the nattress brand transition (hence the title of the clip) but later realized that it was happening for all video transitions.
    MBP 2.2 intel core 2 duo 4gb ram. Osx 10.5.6 FCP 6.x graid 6tb
    Where did this come from?!
    Adam Welch replied 15 years ago 2 Members · 3 Replies
  • Steve Eisen
    July 17, 2011 at 5:30 am
    First trash your render files and re-render.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Adam Welch
    August 17, 2011 at 9:57 pm
    I’m still experiencing this issue. Doesn’t seem to show up until I’m exporting/compressing. Perhaps just a heat issue with my computer?
    I’ve tried changing the sequence render settings from 10 bit yuv to RGB only, no help. I’ve trashed render files and re-rendered, and the problem is gone once the render files are trashed, but re-appears upon completion of the new render.
    Adam
    Adam Welch
  • Adam Welch
    August 17, 2011 at 11:13 pm
    I’ve read other’s similar posts describing the same issue. The only headway I’ve made with it, is that some editors have been able to resolve the issue by extending/shortening their transitions by 1 frame. Apparently there is some issue with the codec or frame-rate that is causing this problem. That solution however, is not working for me this time.
    Adam Welch
