Activity › Forums › Apple Final Cut Pro › FCP 10.4 crashing with XDCAM sd cards
  • FCP 10.4 crashing with XDCAM sd cards
    Posted by Mark Slocombe on December 21, 2017 at 8:16 pm
    If I open FCP x 10.4 while an XDCAM SD card is inserted in iMac, FCP crashes.
    Same if I insert the card when FCP already open.
    Same on 2 iMacs, both High Sierra, both 10.4.
    Copied card to external HD, import from there = same crash
    Dragging the xdcam mp4 from card to Import Media = a green import.
    Tried in iMovie = same green import.
    Anyone else got this? Any suggestions to import XDCAM?
    Mark Slocombe
    https://www.creationvideo.com
    London, England
    Andrew Johnstone replied 7 years ago 12 Members · 28 Replies
  • 28 Replies
  • Graham Read
    January 2, 2018 at 4:13 pm
    Hi Mark,
    Yes, I’ve discovered this too. I’m a long time FCPx user and FCP 7 before that.
    I first had problems with 10.4 on Sierra whereby the import browser was not seeing all the clips on the SXS card. I was in the habit of using XDCAM Browser software from Sony to merge spanned clips rather than the camera archive method that Apple suggest and had been doing this for years.
    The way FCPx 10.4 interprets not only spanned clips but also the forced splitting of clips into 4GB or less due to the FAT32 format of XDCAM EX cards is broken.
    As I have been using this for years I was in the habit of also installing the Sony XDCAM plugin.
    I was keen to try a clean install of High Sierra and on checking the support site, it suggested that the plugin was only required for 10.2 and older versions of FCPx so I have not installed the plugin on my new clean build but curious if it would solve the problem.
    I’m going to file another bug report with Apple – there are not too many people shouting about this problem which is odd.
    I was hoping that a clean install would solve my first problem of not interpreting the SXS card files correctly in 10.4 on Sierra, but sadly not the case – it’s worse with a total crash out.
    Fortunately I’ve got my Sierra system still running and I can import onto a library there and take the drive with me and it then works on my MBP with High Sierra.
    Any thoughts on the necessity of the Sony XDCAM Plugin?
  • Nathan Maskey
    January 4, 2018 at 1:57 pm
    Hi, completely new on here but felt i should leave a message to say i am experiencing exactly the same thing. Don’t usually use Sony ex 3’s but just did a multi camera live switch job using them. Every time I try and launch fcp 10.4 it crashes, if I have an xdcam sd card already plugged in or if I plug one in whilst fcp 10.4 is already running. I have no prior knowledge to using xdcam with fcp prior to 10.4 so I can’t be of much help there, just wanted to let you know that you are not alone. I was able to get around this issue as we always record individual camera feeds back at the switcher via hyper deck minis, but also record internally on whatever camera’s we are using. On this occasion I was very glad I did. Hope someone finds a solution.
  • Mark Slocombe
    January 10, 2018 at 2:04 pm
    Update from me: have been away from office since original post, but today filmed some XDCAM, popped the SD card into iMac with FCPX 10.4 (no update) open… and no crash. Media imported / transcoded ok to FCP X too.. I have no explanation but thought I’d share.
    Mark Slocombe
    London, England
  • Dan Svoboda
    January 11, 2018 at 7:39 pm
    Yes I am experiencing this issue too. I ended up being able to import the cards after several crashes, however the files were not spanned correctly. Very odd behavior, I tried on an old 10.1 system with no issues.
  • Eric Conley
    January 12, 2018 at 11:07 pm
    Graham,
    We don’t have the crashing issue, but we do have the missing clips and spanning issue. Just this week we have started noticing that some clips randomly don’t appear in the import window. Not every card, but there is no pattern to it as well. Spanned clips in the import window now show up as 2 or 3 clips with 01, 02, 03 at the end. If I use the XDcam browser not only do I see the missing clips but the spanned clip-not clips. Is this a 10.4 bug? I am on Sierra using MacBook Pro’s, MacPro’s and a SAN. All of our machines are acting the same way. Any solutions out there?
  • Jim antera Ross
    January 18, 2018 at 4:10 am
    Throwing this out there, hoping it helps:
    iMac 27″ Late 2015
    FCP X 10.4
    OS X 10.13.2
    I have the same problem — with the SD Card with my XDCAM files plugged in, FCP X 10.4 closes within a few seconds. FCP X works fine without the SD Card plugged in.
    Sony Catalyst Browse 2017.3.0.192 accesses my XDCAM files (from a Sony EX1R camera) on the SD Card without problems.
    With SD card plugged in, try opening FCP X 10.4.
    Error message :
    Crashed Thread: 2 Dispatch queue: com.apple.proapps.xdcam.radplugin.requestqueue
    Pro Video Formats v2.0.6, installed with FCP X 10.4
    “Pro Video Formats includes support for…
    Apple Intermediate Codec
    Apple ProRes
    XDCAM EX / HD / HD422”
  • Geoff Addis
    January 18, 2018 at 11:39 am
    Not experiencing this problem in FCPX 10.4/High Sierra when importing from EX1r USB output.
  • Chad Mitchell
    January 18, 2018 at 2:59 pm
    Having this issue in 10.4 with SD card from Sony FS5 – not reading my card clips in import dialogue on my new mac pro. I tried at home last night on my iMac and it worked perfectly…Both on Sierra. Very strange. I’m using a USB 3.0 card reader on the mac pro if that matters…
  • Josh Kaye-carr
    January 18, 2018 at 7:59 pm
    Also experiencing this problem in separate MacBook Pro Retinas running different OS versions (High Sierra and Sierra) while running FCPX v10.4. Using Sony EX-1 camcorder and Sony SxS cards. This problem only appears to have started after upgrading to the latest version of FCPX.
    FCPX launches as expected but immediately crashes upon insertion of SxS card into Sony reader. Copying the BPAV containerized files over to the external RAID does not help, FCPX now crashes on attempted import of those files. I have not found a workaround yet, so I am completely dead in the water when it comes to importing from the EX-1. I do not see a lot of discussion about this problem and am afraid that it is limited to a small number of users. Any assistance would be most appreciated because if we do not get a solution on workaround soon, we will need to look at alternative editing solutions after using only FCPX. Very discouraging to say the least.
  • Dan Svoboda
    January 18, 2018 at 8:19 pm
    That is interesting, because I am able to import if copying the BPAV folder over. Have you tried using XDCAM transfer or Catalyst browse from Sony? I was also able to ingest that way.
    Also make sure you file feedback with apple here.
    https://www.apple.com/feedback/finalcutpro.html
    The more people write about this the more they will see.
Page 1 of 3
