Activity Forums Apple Final Cut Pro FCP 10.1.X Clips Disappear from Timeline
  • FCP 10.1.X Clips Disappear from Timeline
    Posted by David Feldman on April 19, 2015 at 7:51 pm
    I have been using FCP since early 7, then used 10.0 which I like a lot (edits sound; renders on the fly, though some aspects are a bit dumbed down).
    I recently bought a new, maxed out Macbook Pro, 15 inch Ret., 16 GB 1600 MHz DDR3, 2.8 gHz, which runs Yosemite, so I have to run 10.1.3 or .4.
    Great. It’s really fast, as I produce, shoot, and edit a lot of video, commercials, and online TV shows. A lot.
    Recently I discovered a really disturbing, bizarre thing: clips – generally lower thirds or cutaways on layers above my timeline, are disappearing. I thought I was imagining it, but after a client noticed 1 problem with a file and I corrected it, then she noticed 3 others which were not there before, I know it’s a real issue.
    It’s happening a lot and there seems to be no rhyme or reason – I spent hours, I mean hours, fixing things, then hunting down the next problem. Am considering going back to my old Macbook Pro running 10.0, which runs at a snails pace compared to the new system.
    I have tried moving Events and Projects to new Libraries. Haven’t tried working as a new Admin yet, but I shouldn’t have to.
    If there’s a problem, I understand, just give me a workaround. This is not predictible and tells me there’s an inherent instability going on.
    I’m down to importing my exported files and knitting them together just so I get segments I know are ok and which aren’t going to change (since they are single mp4’s). Ugh!
    Doug Metz replied 11 years, 4 months ago 2 Members · 1 Reply
  • Doug Metz
    April 20, 2015 at 8:52 pm
    Hi David,
    Got a few questions for you:
    – is your new laptop running 10.10.3?
    – which version of FCPX are you trying to run, 10.1.3 / 10.1.4 / 10.2?
    – are you allowing Final Cut to update / consolidate your libraries?
    Doug Metz
    Anode
