Activity Forums Apple Final Cut Pro Legacy FCP 10-bit export
  • FCP 10-bit export
    Posted by Jerome Thelia on October 30, 2007 at 7:19 am
    Hi, I searched the forums and can’t find a straight answer to this.
    If I export from an 8-bit timeline (DVCPro HD) using Export to QT, with custom settings of 10-bit uncompressed export, and render settings set to render in 10-bit YUV, will I get a true 10-bit render of effects such as color correction, including MB Looks? Or is FCP rendering to 8-bit compressed DVCPro HD, then making the file? Thanks- Jerome
    Rafael Amador replied 18 years, 11 months ago 2 Members · 1 Reply
  • Rafael Amador
    October 30, 2007 at 9:55 am
    You render with the codec that you have set in your sequence. If you want render and output in 10b your need
    – Set your time-line 10b.
    – If your footage is not 10b, you must set “Render all in high precision YUV”.
    rafael
