Activity › Forums › Apple Final Cut Pro Legacy › FCExpress Help with Archive Files
  • FCExpress Help with Archive Files
    Posted by Cal2007 on August 9, 2007 at 6:59 am
    Our MacBook Pro memory is Full our External HD is Full.
    Need to free up memory, unable to save under archive. [1] Should I save as archive [2] should I just delete old files [3] will that free up more memory on my system.
    Please we also need some help on FC Express on [1] Emailing videos to Clients. [2] also a web designer with good price.
    Calvin
    Russell Lasson replied 19 years, 1 month ago 3 Members · 2 Replies
  • Tom Wolsky
    August 9, 2007 at 10:11 am
    “unable to save under archive. [1] Should I save as archive
    I don’t know what tis means.
    “[2] should I just delete old files”
    If you no longer need them to work with then yes.
    “[3] will that free up more memory on my system.”
    Deleting media wil free up more space. Delete a project file will no very little. Look at your finder in item view and sort the columns based on size to see what’s taking up the most space. Or get shareware called WhatSize to see where the space is going.
    “[1] Emailing videos to Clients.”
    Use of the default small video settings. Most video is too large, unless the project is very short, to be transmitted by email as most ISP have limitations on transfer file sizes by email.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Russell Lasson
    August 9, 2007 at 4:30 pm
    Hey Calvin,
    You probably want to save your project files so that you can make changes to them in the future.
    So a DVD or CD of the project file and any other files that you used that didn’t come from a tape that was shot on a camera.
    Save the original camera tapes that you shot.
    From this you will be able restore the project again if you need to in the future.
    Once you’ve done this, you can delete your files from your computer. (It wouldn’t be a bad idea to restore your project first as a test.)
    The key is to make sure you have what you need before you delete your footage to make space for more projects.
    -Russ
