Activity › Forums › Apple Final Cut Pro Legacy › FCE Still images!!
  • FCE Still images!!
    Posted by Naretha Williams on October 4, 2010 at 8:15 am
    Heya all,
    I know this may sound like we are going over old ground here but I can’t for the life of me work out WHY my high quality professional images look like absolute rubbish when I put them in the timeline and play them back.
    I have been reading through forums and even reading the manual (wild, I know) and am sure I’m forgetting something ridiculously simple as I have seen the image look like I wanted it to ONCE when I was fooling around in motion blur settings. I went back to it minutes later and then couldn’t find my way back to that perfect image. Maybe I was hallucinating, who knows, it was rather late . . .
    Yes I am rendering, have checked all my settings a million times, which is probably confusing things further.
    Its crucial I get these images right and I am really starting to panic as I would have loved to have spent the weekend (and today) actually working on creative content not data management. I’ve even spoken with a couple of editing friends and still no one knows whats going on.
    Please, tell me I’m just having a blonde moment and the fix is as simple as changing obvious setting that I have overlooked.
    I’m working in 4:3 PAL and have tried TIFF, 300dpi jpegs and 72dpi jpegs. Issue is consistent.
    FCE 4
    Please help before I go completely insane 🙂
    Naretha
    Naretha Williams replied 15 years, 12 months ago 3 Members · 4 Replies
  • Rafael Amador
    October 4, 2010 at 3:50 pm
    Hi Naretha,
    You haven’t mentioned,but I guess that your sequence codec is DV.
    If so, set DVCPro50, or Prores, and see if its look better.
    Set your Canvas window to 100% and render to judge the quality.
    rafael
    http://www.nagavideo.com
  • Phil Balsdon
    October 5, 2010 at 10:36 am
    It’s Final Cut Express 4, DVCPro50 and ProRes aren’t an option.
    72dpi, 300dpi are irrelevant in video, its a print only thing.
    You need to refer to the pixel dimension of the complete frame.
    DV PAL is 720 x 576.
    Its not the best format for this type of work. You might be better choosing an HDV AVCHD format.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://www.steadi-onfilms.com.au/
  • Naretha Williams
    October 7, 2010 at 12:12 am
    Hi Rafael,
    Thank you so much for your reply. Its true I’m working in express so not sure how practical this is for me. Thanks anyway.
    Naretha
  • Naretha Williams
    October 7, 2010 at 12:17 am
    Thanks Phil,
    This is good to know (dpi irrelevant in video)
    I am creating a projection work, and the video format which was captured (not by me) is SD 4:3
    My intention was to keep it in 4:3 as it looks better frame wise in the space. Also the image sizes are much better suited.
    I’ll tackle it again tonight and try your suggestions.
    Many thanks for your assistance.
    Naretha
