Activity Forums Apple Final Cut Pro Legacy FCE HD 3.0 “quits unexpectedly” when opening recent projects
  • FCE HD 3.0 “quits unexpectedly” when opening recent projects
    Posted by Dean Mikulla on March 14, 2008 at 5:11 pm
    Let me start by saying that I plan on restoring my G4 and installing FC Studio 2 and starting from scratch. I’ve been using FC E HD 3.0 for a couple years. I learned how to use it while saving all my Projects ,clips and sequences in no particular order, because I just didnt know how to organize files. ( I still dont! kinda)
    I at least saved, ( set the scatch disc), all my video clips on to the external G DRIVE Q. I’m hoping that I’ll be able to access those raw video clips I captured using FCEHD3.0 with FCP6 after i install and start using it.
    As far as the original subject,
    I’ll have FCEHD3.0 open, when I try to open a recent project, fce “quits”. I can only open projects from the autosave vault from prior to approx. 11/07′ I trashed preferences and ran disk utilities. And its still the same. I might add that since I trashed the preferences , all new projects have worked great.
    What would cause this?
    Could there be corrupt files on my external drive also?
    Is there a way to delete all my FCEHD3.0 files on both the G4 and the G Drive Q but still keep the raw DV clips available for use in FC Studio 2 Suite later?
    thanks , Dean
    Machine Name: PowerBook G4 15″
    Machine Model: PowerBook5,8
    CPU Type: PowerPC G4 (1.5)
    Number Of CPUs: 1
    CPU Speed: 1.67 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 2 GB
    Bus Speed: 167 MHz
    Boot ROM Version: 4.9.6f0
    Serial Number: W85441XGSWZ
    FCE HD 3.0
    G DRIVE Q 250g
    Dean Mikulla replied 18 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
