Activity › Forums › Apple Final Cut Pro Legacy › FC7 and render management?
Posted by Liam Lawyer on July 28, 2009 at 4:21 amHey all!
How is the new ‘render management’ with FC7? Can’t be any worse I guess…
Liam Lawyer
-editor-Jason Brown replied 17 years, 1 month ago 5 Members · 4 Replies -
Russell Lasson
July 28, 2009 at 5:00 amRender manager shows the render files related to each sequence in your project. So if it’s not part of the current sequence, you can dump it.
Also, FCP does a better job at having rendered effects act like clips. So you can duplicate it and move it around, trim it, add a transition without having to re-render the clip.
-Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net -
Neil Sadwelkar
July 28, 2009 at 8:00 amWhat about if you switch the track visibility. Does that lose render files?
Neil Sadwelkar
neilsadwelkar.blogspot.com
FCP Editor, Edit systems consultant
Mumbai India -
Craig Whitaker
July 28, 2009 at 12:45 pmNot having to re-render clips if you move them or add trans to them seems like a HUGE improvement…something like this is worth $300 to me easily.
