Activity Forums Apple Final Cut Pro Legacy FC-Express “unrendered error” Help
  • FC-Express “unrendered error” Help
    Posted by Alex Copeland on October 24, 2009 at 12:33 am
    Thanks in advance.
    Trying to add material to timeline from canvas and getting “unrendered” error, no playback and this red double line above time-line.
    Computer: Macbook
    OS: 10.6.1 (Snow Leopard methinks)
    Program: FCE 4.0
    Camera: (Cheapy) Sanyo Xacti cg10
    Video Specs from QT:
    Format: H.264, 1280 X 720, Millions AAC, 2 channels, 48000 Hz,
    FPS: 29.97
    New to Apple, FCE and the camera but willing to provide any information that will help you help me.
    Alex
    David Mosquera keith replied 16 years, 10 months ago 2 Members · 1 Reply
  • David Mosquera keith
    November 20, 2009 at 2:59 pm
    you need to render the sequence!
    That is because because your footage probably doesnt have the same settings as your sequence. right click in your sequence then settings and there you will see diferent presets you can choose from, choose the one matching your footage and it wont say unrendered.
    Another way could be just rendering that footage on that sequence you are using but this will work only depending of the settings of the sequence but just try rendering the sequence presing alt + r see what happens…
    Dave.
