Activity › Forums › Sony Cameras › FC: Export to XDCAM works great
  • FC: Export to XDCAM works great
    Posted by Rafael Amador on November 29, 2008 at 1:13 pm
    Hi COW-addicts,
    I’ve been making a test with the new XDACAM Transfer function.
    Really easy and fast. To export 3 minutes of EX-1 footage took a bit more than 1 minute.
    No re-compression, only the GOPs of the cuts needs being rebuilt (I think).
    I’ve exported a 1080i50 and a 720p25 sequence.
    Then I tried to recapture with the JAioHD to SD.
    No problem with the 1080i. Converted to PrtoRess looks great.
    With the 720p25 I had some difficulties for setting the AJA Control panel properly, but in the end I’ve got it.
    I think is a good workflow when needed to downsize a lot of XDCAM footage. Good quality and really fast.
    Cheers,
    rafael
    http://www.nagavideo.com
    Rafael Amador replied 17 years, 9 months ago 3 Members · 4 Replies
  • Chris Babbitt
    November 29, 2008 at 6:31 pm
    Please clarify, Rafael. What Transfer Function are you talking about?
  • Rafael Amador
    November 30, 2008 at 2:52 am
    Hi Chris,
    The XDCAM Transfer 2.8, install a plugin in FC that allows to export back to the SxS card.
    I’m working in a project that mix DV and Ex-1 footage. I used this function to convert to ProRess SD all the EX-1 footage of my time-line. Fast and perfect results.
    Cheers,
    rafael
  • Paul Campbell
    December 3, 2008 at 8:32 pm
    Hi, Rafa. I was browsing the XDCAM forum and found this thread. (I’m the guy you were helping a few days ago trying to downconvert XDCAM footage at 24fps to SD @ 30fps) Needless to say, I’m still experimenting with getting the best downconversion possible. I haven’t had a chance yet to purchase the Natress application you mentioned.
    Forgive my ignorance here, but I don’t understand why you’d take XDCAM footage from the SxS card and convert it to put BACK on the SxS card. Maybe I just misread your first post. The reason I ask is because I’m still looking for that perfect way to convert my XDCAM footage to a SD timeline to mix with some SD graphics.
    I have access to an AJA Kona I/O. Would your procedure for downconverting work with this?
  • Rafael Amador
    December 4, 2008 at 2:54 am
    Hi Paul,
    I’m ediiting EX-1 together with some DV in an SD time-line. What I put back to the SxS card are the EX-1 shots. I send them from an EX-1 sequence, un-scaled off course. There is no rendering so no quality lose. Then I capture then as ProRess SD with the AJAioHD.
    I’m afraid you can’t do that with the I/O because it have no HD capabilities. But you can try converting in the camera. You can output SD from the HDI/SDI and capture that with your AJA.
    Rafael
