Activity Forums Apple Final Cut Pro Legacy FC doesn´t open anymore!!
  • FC doesn´t open anymore!!
    Posted by Javier Ortega on January 22, 2010 at 9:46 am
    FC doesn´t open anymore, it seems to start opening, but it doesn´t. I removed the “Final Cut Pro User Data” folder from the Preferences folder and the “com.apple.finalcutpro.plist” file from the Preferences folder. No success. I formated the computer and tried to reinstal FC but with the same result.
    What can I do?
    Thanks for your help.
    Javier Ortega replied 16 years, 7 months ago 2 Members · 2 Replies
  • John Fishback
    January 22, 2010 at 5:29 pm
    What computer, what version of OS & FCP? The more info you supply the easier it is for us to help.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Javier Ortega
    January 22, 2010 at 5:39 pm
    Thank you very much for your quick response.
    I found the solution! I was missing the Pro Fx file in /Library/Frameworks/ProFX.framework/Versions/A/ProFX and the one in /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport.
    I don´t know why they disapeared. I copied the files from another Mac and now its working!
    Thanks a lot
