Activity Forums Apple Final Cut Pro Legacy FC 7, Red Proxy to ProRes
  • FC 7, Red Proxy to ProRes
    Posted by Kevin Reeves on December 18, 2009 at 7:33 pm
    Hey there, I am working on a 2 hour film where the original editor cut with Red Proxy Files. This project is huge it literally takes me 20 minutes to open up and we have a pretty fast mac. It is very sluggish trying to move through the timeline. My question is, is it possible to take the finished cut sequence and transcode those proxy files to prores? I know you can when you import the files themselves. im just not sure how you do it when the files are already in the project and on the timeline.
    Kevin Reeves
    https://www.kappastudios.com
    Kevin Reeves
    kevin@kappastudios.com
    http://www.kappastudios.com
    Rob Wilson replied 16 years, 9 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    December 19, 2009 at 4:38 am
    I think if you used the media manager to transcode/copy the sequence (might want some handles too) you’d end up with a ProRes version. If the proxies were the 2k files, you’d have high quality too.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Rob Wilson
    December 19, 2009 at 9:05 pm
    If you get the original R3D files and input them into Red Rushes (free to download from red website) you can export as prores (or prores proxy) from there, as long as you keep the file names the same you should just be able to reconnect to ProRes.
    Rob
