Activity › Forums › Apple Final Cut Pro Legacy › FC 6
Posted by Alan Stephens on June 23, 2007 at 2:19 pm
Can I upgrade and load FC 6 and still keep FC 5 on the same system?
I could do that with Premier Pro.
Is it true you can’t open a FC 5 project in FC 6?AJS
Bret Williams replied 19 years, 3 months ago 8 Members · 11 Replies -
Walter Biscardi
June 23, 2007 at 4:50 pm[AJS Studios] ”
I could do that with Premier Pro.”No, unless you have two completely different boot discs.
[AJS Studios] ”
Is it true you can’t open a FC 5 project in FC 6?”You can open an FCP 5 project in 6. You cannot open an FCP 6 project in 5.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
David Roth weiss
June 23, 2007 at 4:53 pm[AJS Studios] “Can I upgrade and load FC 6 and still keep FC 5 on the same system?”
Only by creating a dual boot system, or by cloning your system drive to a removable drive and upgrading either the original or the clone to FCS 2.
I cloned my system drive to a firewire drive, put that away for safe keeping, and upgraded the internal system drive to FCS 2. Later, a client still using FCP 5.1.4 brought in a color correcting job thet needed to stay at ver 5, so I simply booted to the firewire clone and went to work on their job.
[AJS Studios] “Is it true you can’t open a FC 5 project in FC 6?”
That is not true. You can always open a project from an earlier version. However, once you save it as a ver 6 project you can’t go back and open it in an ealier version.
“No job is worth doing more than once…”
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles -
David Roth weiss
June 23, 2007 at 4:55 pmWalter,
You are fast on the draw today. My caffiene is has not yet begun to work…
David
David Roth Weiss
Los Angeles -
Bret Williams
June 23, 2007 at 5:04 pmI must be some sort of magician.
When I installed 6, I simply dragged 5 over to another drive and unmounted it.
After installing 6, I put FCP 5 it back in the apps folder and called it Final Cut Pro 5.
Both seem to work just fine. They have different prefs in the library.
This is just a basic setup. Not sure how it would work with Kona or something, but give it a shot.
Shane Ross
June 23, 2007 at 5:50 pmI have heard that those with non-intel macs have been able to keep older versions, while those with MacPros can’t keep the FCP 5.1 version working.
Is that what’s happening to people here?\
Shane
Littlefrog Post
http://www.lfhd.net -
Bret Williams
June 23, 2007 at 6:44 pmI think you meant wiped?
Not if you move it to another drive and unmount the drive.
Anyway, I haven’t done any vigorous testing. But just opening 5.1.4 after installing 6 seems to play back and operate. I’m looking for some knowledge that there is a specific reason it won’t work or a reason not to use it if need be.
Jeremy Garchow
June 24, 2007 at 12:05 am[Bret Williams] “I must be some sort of magician.”
…or lucky….
From apple:
https://docs.info.apple.com/article.html?artnum=305389
and
https://docs.info.apple.com/article.html?artnum=304983
Rich Rubasch
June 24, 2007 at 3:36 amHey guys….ever since FCP 3.0 I have simply renamed my app file….Final Cut Pro becomes Final Cut Pro 5.1.4. Then I load the new version….still have the old version. Works for the entire suite. I have Motion 2 and 3 on the same G5. Final Cut Pro versions 3 all the way to version 6…all running fine, all plug ins intact. I always do this to be sure I can do what Walter does with the older version if I have to, but I don’t have to reboot.
Hmmm, not sure why it is so easy, but a reboot drive is not necessary….again, I’m on G5’s still so I don’t have experience using this method on an intel.
Just rename the app file before installing the new version!!!!
Rich Rubasch
Tilt Media
