Activity Forums Maxon Cinema 4D FBX sequence export for Autodesk Flame
  • FBX sequence export for Autodesk Flame
    Posted by Timothy Montgomery on August 22, 2013 at 3:01 pm
    Hi all,
    I’ve got a animated 3D logo in Cinema 4D. Animations include a boolean effect which seems to be un-bake-able and two FFD deformer animations which I’ve successfully baked using the point cache tag. I would now like to export each frame of the animation to FBX frame sequence to import into Flame. I cannot seem to figure out how to get Cinema to actually create the sequence and can only get a single frame of the build (whatever frame the time positioner is on when I export).
    I admit I’m not an expert on FBX, so if I’m missing something obvious I apologies. Thanks for any help in advance.
    -Monty
    David Cabestany replied 12 years, 2 months ago 2 Members · 2 Replies
  • Timothy Montgomery
    August 27, 2013 at 1:12 pm
    So no one has any ideas on exporting FBX sequences?
  • David Cabestany
    July 9, 2014 at 6:52 pm
    Hey Tim, did you ever figure this out?
    I’m trying to do the same here.
    Best,
    David.
