Activity Forums Maxon Cinema 4D .fbx file question
  • .fbx file question
    Posted by Orrin Zucker on August 17, 2010 at 11:22 am
    Hi-
    I’m a newbie to c4d.
    I just received an .fbx file from Maya. When I merge it into c4d I can see that something is there – the model with all the parenting appears in the object area…but nothing is visible. The size is 0 and it’s not editable.
    Any insight would be appreciated. Would another format from Maya be preferable (It needs to preserve the nurbs info ).
    Much thanks in advance.
    Adam Trachtenberg replied 16 years ago 2 Members · 1 Reply
  • Adam Trachtenberg
    August 17, 2010 at 3:02 pm
    You might check the options preferences>import/export and try some other options. I’m not familiar with Maya’s export options, but if it supports Collada you might give that a try.
