Activity › Forums › Apple Final Cut Pro Legacy › favorite codec from Motion for FCP projects
  • favorite codec from Motion for FCP projects
    Posted by Tad Newberry on August 14, 2010 at 7:16 am
    i’m normally trying to work in ProRes (“reg”, not HQ nor LT) and trying to come up with the most efficient output from Motion 4 to use on a Pro Res timeline. These are files with alpha channels (lower third type stuff), so need transparency. So far, the best seems to be lossless + alpha animation movies. i’ve tried some of the ProRes settings, but never seem to get a transparent background with them.
    Tad Newberry replied 16 years, 1 month ago 2 Members · 4 Replies
  • Rafael Amador
    August 14, 2010 at 2:59 pm
    Hi Tad,
    The only Prores that supports Alpha is the 444{4}.
    You need to set “Millions +” to export with the alpha.
    rafael
    http://www.nagavideo.com
  • Tad Newberry
    August 14, 2010 at 4:14 pm
    ah, cool…and would there be any advantage in rendering out Motion files as PR 4444 over a lossless animation type?
    thanks for helping out a bonehead!
    __________________________
    2.66 GHz Quad-Core Mac Pro
    3GB RAM
    NVIDIA GeForce GT 120
    …and a few TerraBytes o’ storage
  • Rafael Amador
    August 14, 2010 at 5:11 pm
    You get a 10b Alpha Channel instead of the 8b of the Animation and also 10b YUV instead of 8b RGB, an in a codec that works much better in Fc (RT)..
    Not enough?
    Prores 444 has been designed right for whar you intend to do.
    Animation is a relic.
    Cheers,
    Rafael
  • Tad Newberry
    August 14, 2010 at 5:23 pm
    Thanks! I’ll keep all that in mind and head in that direction…now if i could only track down this continual crashing in FCP! I think i have a corrupted file somewhere. Upon upgrading to Snow Leopard and FC3 a few days ago, everything was working GREAT – in a new ProRes-only timeline. Then i opened up and older project, crash, crash, crash, tried to export/share overnight – crash. I just uninstalled my BlackMagic software and seeing if this makes a difference…(still rendering/exporting – so far – right now!)
    3GB RAM
