Activity Forums Adobe After Effects Favorite Animation Export Formats? Best for YouTube?
  • Favorite Animation Export Formats? Best for YouTube?
    Posted by Brent Taylor on June 21, 2015 at 3:37 am
    I’m working on an animation in After Effects. Most of the assets come in from Illustrator.
    In general I’ve been using the Quicktime format and the Animation codec at 100 to export. The files are pretty huge, but if I run them through again in Premiere with the same settings, they get considerably smaller and still look great. The eventual destination is YouTube.
    However, for some reason this one scene I’m working on looks terrible on YouTube. Everything looks like a bad bitmap image. I noticed that this particular scene doesn’t get any smaller when I do the second pass, either. There IS a lot more going on in it than usual.
    Anyhow, does anyone have any suggestions? The video looks fine until it goes to YouTube. Is there another format I should try?
    Adam Videoeditor replied 11 years, 2 months ago 2 Members · 1 Reply
  • Adam Videoeditor
    June 23, 2015 at 3:58 pm
    The render settings I use in After Effects are
    Format: H.264
    Profile: Main (Under format options)
    Level: 5.1 (Under format options
    Bitrate Encoding: VBR, 1 Pass
    Target Bitrate: 30
    Maximum bitrate: 50
    In Premiere Pro I use
    Format H.264
    Frame Rate: 29.97
    Aspect: Square Pixels (1.0)
    TV Standard: NTSC
    Profile: Main
    Level: 5.1
    Bitrate Encoding: VBR, 2 pass
    Target Bitrate: 30
    Maximum Bitrate: 50
    Audio Codec: AAC
    Sample Rate: 48000
    Bitrate 192
    -AD.VideoEditor
    Please follow me on Twitter @ADVideoEditor and subscribe to my youtube channel Ad.VideoEditor
    https://www.youtube.com/channel/UCtJAZgXTU0C4ir0N1P7Oxyw
