Activity › Forums › Adobe After Effects › faux 3d box
faux 3d box
Posted by Martin Stacey on June 9, 2006 at 11:01 amHi ya, i need to create a box which looks like this:
https://www.othersidecreation.com/martin/stuff/box.jpg
but it needs to be 3d. is that possible? i know you can’t make it cause of the messed up perspective, but i just wondered if there was a plugin?
cheers
Justin Productions replied 20 years, 3 months ago 4 Members · 5 Replies -
Steve Roberts
June 9, 2006 at 12:52 pmNot sure what you’re asking for:
1. A 3D box made up of four planes? AE can do this. Make a new solid with the dimensions of one side of the box, give it maybe 50% opacity and click the little 3D box. Make a 3D camera. Don’t work in 3D without making a camera, or you may get hosed later. Dupe the four sides. Rotate them and move them into position to forma a square.
2. A box in isometric perspective as you’ve shown? Sorry, AE doesn’t do isometric. To make this, you’d have to fake it with a flat illustration of four parallelograms, but it wouldn’t be 3D.
Steve Roberts
June 9, 2006 at 1:06 pmSorry, now I understand. You wanted to make #2, but now you know you can’t do that in AE. 🙂
And I was wrong — that’s not isometric, that’s a cavalier or cabinet projection, if my sources are accurate.
Sam Moulton
June 9, 2006 at 3:02 pmyou can do it if the sides of your box are not squares. using the jpg as a guide create a solid say 300 X 300 pixels, make it 3d, set the z anchor point to -100, rotate the x value of 1 by 90 the next by -90, the next rotate y by 90 and then last by -90. now you have a box with sides that are too big. create a camera with a zoom of say a million and then position it so the box is approximately in the same position. now use the mask tool to trace the angles of the box using your jpg as a guide and fine tune the orientation to make them line up. I did it in about 5 minutes using your jpg. You now have a 3d box that looks just like the jpg. the only problem is when you then move the camera. it gets real funky because the box isn’t square.
Justin Productions
June 9, 2006 at 3:02 pmThat’s very easy to do with the Zaxwerks Invigorator plug-in. Just did one and it took me less than a minute.
Cheers.
Justin Productions
Tangerin01@hotmail.com
Adobe After Effects 6.5 Professional
