Activity › Forums › Canon DSLR Cameras › Faulty SD Card when using 60d? (Sorry if this is the wrong forum!)
  • Faulty SD Card when using 60d? (Sorry if this is the wrong forum!)
    Posted by Scott Norris on January 24, 2013 at 3:11 pm
    Just attempted to upload the footage from a recent corporate shoot. This was the result:
    Any ideas on how I can recover the data? Is the SD busted?
    Thanks in advance!
    Scott
    Scott Norris replied 13 years, 8 months ago 2 Members · 2 Replies
  • Sareesh Sudhakaran
    January 25, 2013 at 3:32 pm
    Do the files contain data? The sizes will tell you if this is the case. Can you try the card on another machine?
    If the card does contain data, then try renaming the file manually with the right extension and see what happens. Hope this helps.
    https://www.wolfcrow.com – Workflow information and support for filmmakers, photographers, audiographers and videographers.
  • Scott Norris
    January 26, 2013 at 3:38 pm
    Unfortunately it reads as 0KB, it won’t even playback on the camera now, tried a couple of recovery program demos as well, but no luck! Thanks for trying.
