Activity Forums Adobe Encore DVD Fatal Error Code 6
  • Fatal Error Code 6
    Posted by Joe Bandy on January 17, 2009 at 8:13 am
    I have been trying to build a Blu-Ray disc in Encore CS3 and have been receiving an error that states:
    Fatal Error Code 6
    I think this is referring to a region code but encore doesn’t allow you to specify any regions for B-Ray anyway.
    Does anyone know what this means?
    Daniel Gonzalez replied 16 years, 8 months ago 4 Members · 4 Replies
  • John Rich
    January 17, 2009 at 2:29 pm
  • Joe Bandy
    January 21, 2009 at 5:14 am
    I tried installing the patch onto one of our two editing systems and ran a small test which worked!
    I’m going to try to make a Blu-Ray tomorrow. I’ll let you know what happens.
  • Wesley Cardone
    August 13, 2009 at 11:02 pm
    I see this from time to time and it is nerve wracking. Here is one thing I have found that sometimes solves the problem.
    Look or search recursively in the project directory for any *.log file. Look in that file with Wordpad so that it doesn’t look like a hash of text like Notepad would show. Scroll down to the bottom and look for an error message about an orphaned file, usually a menu. In the project edit that menu in Photoshop simply saving it as a Photoshop file to some different name outside of the project. In Encore delete that menu. Quit Encore saving your work. Restart Encore and add that Photoshop file as a menu from the external location. Reattach whatever it had and run with it.
    More than likely if there was an orphaned file this will fix the problem.
  • Daniel Gonzalez
    January 16, 2010 at 3:12 pm
    To me when I appeared to a playlist of chapters and included a chapter of a brand-timeline without final action (which in my case was the first, That did not correspond with any chapter, But with the beginning of my movie)
    Adding to that first makes a final action and did not give me error, I hope this helps someone who is like me, Peleandose with this hateful and wrong program.
    Which would give a DVD Studio Pro with authorship of blue ray…
