Activity › Forums › Apple Final Cut Pro Legacy › Fastest way to export lowest quality video for Dailies??
Posted by Evan Seitz on December 16, 2010 at 7:36 pmHey guys – I’m currently spitting out Dailies of high quality 1920×1080 footage (usually 10 minutes to an hour in length) with a burned in timecode layer.
I need to get these out to producers as fast as possible and don’t care about quality! What is the FASTEST method?
(I’ve been doing the lowest quality MPEG at the lowers screen size (like 300×200 or something) – but it sometimes takes up to 20 hours (probably due to the burned in timecode)…
Martin Robertson replied 15 years, 1 month ago 9 Members · 12 Replies -
Jenna Bliss
December 16, 2010 at 7:43 pmhave you tried doing a quicktime conversion using the lowest streaming quality, single pass? H.264 is probably faster than mpeg.
Jenna D Bliss
David Roth weiss
December 16, 2010 at 7:54 pm[Evan Seitz] “it sometimes takes up to 20 hours (probably due to the burned in timecode)…”
No, it take 20 hours because you’re not rendering first, and because you’re not then exporting a self contained QT to use for the encode to a compressed codec.
Also, h.264 offers the best quality, but it is the slowest of all the compression codecs, so I hate to disagree with Jenna, but stick with your earlier choice of mpeg.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Jenna Bliss
December 16, 2010 at 8:08 pmActually H.264 and MPEG have identical technical content.
Jenna D Bliss
Evan Seitz
December 16, 2010 at 8:11 pmCorrect me if I’m wrong:
1. I should render the entire timeline
2. File -> Export using compressor
3. Select Self Contained
4. Select Mpeg (Lowest settings)
Or do I export out a self contained .mov and then compress into a Mpeg using compressor, etc???
Shane Ross
December 16, 2010 at 8:12 pmLook at ProxieMill from https://www.imagineproducts.com. It does this in the background, while you are capturing, ingesting…or OFFLOADING the tapeless media. The producers can walk away with dailies on the day of the shoot.
Shane
Read my blog, Little Frog in High Def -
David Roth weiss
December 16, 2010 at 8:16 pm1) render the entire timeline
2) export using Export>>Quicktime Movie (current settings)
3 the use that exported file in Compressor or, for even faster encodes, use Streamclip.David Roth Weiss
Los Angeles
Gary Askham
December 16, 2010 at 9:06 pmHow well do you know Compressor? Do you have a cluster or multicore computer?
If so then the fastest way would be to bring your footage directly into Compressor and export a 320×240 Mpeg1 (fast to encode, compatible with Windows and Mac systems).
Compressor has it’s own Timecode Reader which on it’s own is crap because it can only be one colour – so it can sometimes blend into the footage. But if used with a cleverly placed Watermark overlay (created in Photoshop) then you can create a black box to go around your timecode.
It might take 10 minutes to set all this up but once you have done you can reuse the preset over and over.
This way you don’t have to render anything – and all the processing is done within Compressor which is multi-processoe aware (if set up properly).
FCP and Avid Technical Support
Air Post Production
Shoreditch – London -
Matt Lyon
December 16, 2010 at 11:06 pmGood tips Gary, but if the OP is using a timecode reader filter, for per-shot timecode, then the Compressor timecode generator won’t do the job.
You can also turn on the frame controls in compressor and set the resize quality to “Fastest” for an additional speed boost.
In the past I’ve worked on shows that use a playback deck connected to a DVD video recorder. Not sure if that is an option here, but those things go for pretty cheap these days…
Matt Lyon
Editor
Toronto -
Ben Hendriks
December 17, 2010 at 8:23 amOr if your daillies are for viewing only, playout your timeline to a DVD recorer in realtime.
Regards Ben
