Activity Forums Adobe After Effects Fastest Green Screen Rendering Quad Core
  • Fastest Green Screen Rendering Quad Core
    Posted by James Purdie on September 3, 2009 at 9:03 pm
    Hi there,
    I got a quadcore (AMD 9950), XP. I’m looking to increase my render times for green screen footage.
    Presently, with a basic video background it takes about 20 minutes. with a stationary background about 14 minutes.
    I’m doing HD 1140 by 1080 with the WMV files( which I like) on their highest settings.
    In particular, should I be trying to do this with the XP 64 bit OS or does it matter very much. Also, is it much faster with all four processors working together. Presently I don’t really enough RAM. So I need more. It appears that my video card doesn’t support the Keylight plugin because AFX CS3 crashed during rendering.
    Any tips would be greatly appreciated.
    James Purdie replied 17 years ago 3 Members · 5 Replies
  • James Purdie
    September 3, 2009 at 9:30 pm
    Thanks for the reply. I appreciate it. I realize rendering is fundamentally a slow process, especially as more things get computed.
    Is the multiprocessing thing not much of a time saver? I only have 2 gigs of ram in this computer right now, so i’m not using that option presently.
    Rock on!!
  • Joe Moya
    September 4, 2009 at 4:19 am
    If your looking for faster renders… the best cheapest gain would be moving up to at least 3Gigs of RAM (2,4 or 6 Gig RAM is preferred for most mobo’s) …. Second (but definately not the cheapest), you could go with is a Adaptec Raid card setup using e-sata 15k rpm Fujitsu Drives. At least one set of dual HD/stripe raid for your disk cache and another set of dual HD’s/stripe setup for your operating system/software application. That set up will be a 4 drive (i.e., 2 striped raid) setup. You could repeat this set up for each disk cache drive setup you want to use…(see the Media and Disk cache setup preferences).
    Multi-processors are a step up in speed (specially with 64bit OS)… but, typically the biggest bottleneck is the Hard Drive (and, the HD’s search time for long renders).
  • Hannes Paulsson
    September 4, 2009 at 12:30 pm
    I’m using win7, a dual quad core (inte i7) and 12 gbs of ram, and it works fine!
  • James Purdie
    September 4, 2009 at 4:00 pm
    That’s very interesting about windows 7. I recall them even saying they “compatibility modes” as well if necessary.
    Just out of curiosity, how long would take to render a minute of greenscreen footage on your computer?
    thanks
  • James Purdie
    September 4, 2009 at 4:08 pm
    Also….are you using a 32 or 64 bit version of Windows 7? I’m not sure if After Effects works with a 64 bit version or does it?
