Activity › Forums › Apple Final Cut Pro Legacy › Fastest Express Card (eSata) for MacBook Pro?
Posted by John Leblanc on July 15, 2009 at 6:41 pmI’m trying to find the fastest eSata ExpressCard for a new 17″ MacBook Pro? Any suggestions, experiences?
Rafael Amador replied 17 years, 1 month ago 6 Members · 7 Replies -
Shane Ross
July 15, 2009 at 6:45 pmCalDigit FASTA card. Never had an issue with it.
Shane
Read my blog, Little Frog in High Def -
Jeremy Garchow
July 15, 2009 at 7:00 pmThe Sonnet Tempo Sata PRO (different from the regular).
https://sonnettech.com/product/temposataproexpress34.html
Jeremy
Jim Glickert
July 16, 2009 at 2:08 amHi John. I use the CalDigit FASTA card with a CalDigit S2VR DUO RAID drive and MacBook Pro, and it works great. All of my video work is in HDV. As to whether it’s the fastest card available, I don’t know, but it’s fast enough for me.
Jim
Ed Dooley
July 16, 2009 at 6:07 pmAs Jeremy said, the Sonnet:
Barefeats.com says that the Sonnet Tempo Pro is faster than all others because it uses the Marvel chip instead of the more common SI chip.
Edhttps://www.sonnettech.com/product/temposataproexpress34.html
This from barefeats.com:
The Sonnet Tempo SATA Pro ExpressCard/34 is unique among SATA ExpressCards in that it is the only true SATA adapter. Other brands say “SATA” but are actually using USB protocols. The result is that the Sonnet Tempo Pro produces much higher transfer rates. For example, when we connected the OCZ Vertex SSD to various SATA ExpressCards, the Sonnet Tempo Pro was 55% faster reading and 103% faster writing compared to the fastest alternative SATA ExpressCard -
Rafael Amador
July 16, 2009 at 6:22 pmThe tests of the Sonnet are almost three years old.
I think most of the eSATA Express cards are 1.5 Gbps, while the FASTA Cal-Digit, pointed by Shane, is 3 Gbps.
So in theory it could reach double speed of any of his competitors.
Cheers,
rafael -
Jeremy Garchow
July 16, 2009 at 6:47 pm[Rafael Amador] “The tests of the Sonnet are almost three years old. “
No sir, they have a new card out. The Pro version which is here:
Their regular (slower and less RAM friendly) version is here:
https://sonnettech.com/product/tempo_sata_express34.html
The barefeats test of those drives is from July 6th 2009, here:
https://www.barefeats.com/note06.html
The note that Ed included is from that page:
(* The Sonnet Tempo SATA Pro ExpressCard/34 is unique among SATA ExpressCards in that it is the only true SATA adapter. Other brands say “SATA” but are actually using USB protocols. The result is that the Sonnet Tempo Pro produces much higher transfer rates. For example, when we connected the OCZ Vertex SSD to various SATA ExpressCards, the Sonnet Tempo Pro was 55% faster reading and 103% faster writing compared to the fastest alternative SATA ExpressCard.)
Jeremy
Rafael Amador
July 16, 2009 at 8:03 pmHi Jeremy,
Thanks for the update.
Up to those tests I have to recognize that it runs like a 50% faster than my LaCie with my Caldigit VR and a 25/15% with the LaCie LittleBigDisk. All this with a MBP 2.4 Ghz.
Would be interesting a test comparing directly both cards (Sonnet/Caldigit).
Cheers,
rafael
