Activity › Forums › Adobe After Effects › Faster way to place or nudge all images out of subpixel position
  • Faster way to place or nudge all images out of subpixel position
    Posted by Matt Shoesmith on June 13, 2016 at 11:40 pm
    Is there any way, plugin perhaps, to help prevent having any keyframed subpixel positions? (not sure if that’s the term but I’m referring to when the difference between the anchor and position is not a whole number) It takes a lot of time to nudge my images out of subpixel positions when I first bring them into AE, then I also need to be careful where I reposition them when animating. I don’t want any keyframed positions using subpixels and I don’t want to disable subpixels. The dream would be a plugin window which at the click of a button nudges either the position or anchor point of every keyframe at the current time out of subpixel position. Anything that could help?
    Matt
    Jerry Smith replied 10 years, 3 months ago 2 Members · 1 Reply
  • Jerry Smith
    June 14, 2016 at 3:40 pm
    I had a similar problem and I ended up spending a few days writing a script. I’m not positive about your situation because of the keyframing, but I’d lay 10-1 that there exists a 20 line script that just goes through and changes all the positions and anchor point keyframes to just the integer part. You’ll be so happy when you see that script run.
