Activity › Forums › Boris FX Particle Illusion › faster twinkling magical effect
  • faster twinkling magical effect
    Posted by Joeyboy on July 7, 2006 at 11:05 am
    hi,
    how do i create a fast twinkling sparkles effect while having the particles not die fast. i want it to continue it’s movement in the direction i choose, and it musn’t disappear for the duration that i set. but i need a magical pixidust effect (fast twinkling). just an area emitter and let the particles move up or downwards.
    thanks
    Joeyboy replied 20 years, 2 months ago 2 Members · 2 Replies
  • Alan Lorence
    July 7, 2006 at 5:50 pm
    Make sure that the alpha (transparency) gradient for the particle starts and ends black, and goes white in the middle, then slide the “repeat” slider to the right. If you slide it all the way right (which I believe the value is “10”) and that’s still not enough “sparkle”, then add points to the gradient so it goes black / white / black / white etc.
    Alan.
    wondertouch
  • Joeyboy
    July 10, 2006 at 7:34 am
    thanks a lot alan, this is exactly what i need!
