Activity Forums Maxon Cinema 4D Faster Rendering
  • Faster Rendering
    Posted by Eric Gross on June 30, 2010 at 11:30 pm
    Okay so I have a bunch of text and my camera flys from one to the next. I know, I know, Original right? Okay I’m wondering since I’m not going to see these texts after I pass them is there anything I can do to increase my render speed?
    I use a display tag so that I can turn off visibility of text I don’t want to see until it gets where I want to see it. But I don’t know if that helps or not.
    Brian Jones replied 16 years, 2 months ago 2 Members · 3 Replies
  • Brian Jones
    July 1, 2010 at 3:38 pm
    Faster computer is the easy answer but it also depends a lot on the textures – how expensive they are in calculation time, what other pre/post processes you are using (GI is a biggy) – What’s the light setup etc. Need to know more (or see the scene file)
  • Eric Gross
    July 1, 2010 at 6:40 pm
    Thanks for the response.
    Well the texture I am using does have a lot of reflections and it is high definition. Scene has eight lights, four groups of text (extruded type with caps) and a reflective floor. I’m not rendering GI.
    I am still learning so maybe I am missing something.
    I would think my 2.93 octo-quad Mac with NVIDIA Quadro FX 4800 and dual monza exhausts would be able to handle it easily enough…
  • Brian Jones
    July 2, 2010 at 3:28 am
    Should be quick enough, yes. Without knowing more I can’t do anything but guess. Area lights? Reflection with dispersion? Render expensive noises being used? It doesn’t look very complex from that screen shot…
