Activity Forums Apple Final Cut Pro Legacy Faster rendering w/plugin in Motion vs. FCP?
  • Faster rendering w/plugin in Motion vs. FCP?
    Posted by Ryan Ritchey on December 8, 2010 at 3:38 pm
    Hi everyone,
    I have a project I need to do heavy work with Neat Video’s noise remover to fix. Using the plug-in in FCP, I’m looking at a six day render. The plugin also works in Motion, and I’m curious if I would be able to get results faster there. Ideally, I need to a shave a day off the render. I’m about 6 hours in, so I don’t want to stop the render to test it in Motion.
    Paul Jay replied 15 years, 9 months ago 2 Members · 1 Reply
  • Paul Jay
    December 8, 2010 at 5:05 pm
    Motion uses the GPU for most work. Just do a test and compare.
    Apps like After Effects CS5 will help you more as they can use all cores and memory for rendering.
