Activity Forums Adobe After Effects Faster Rendering with both AE and PP CS6
  • Faster Rendering with both AE and PP CS6
    Posted by Shane Sackett on February 12, 2013 at 5:10 am
    Hi everyone, I recently bought a computer to handle hd video editing and rendering better than my previous one. However, I notice that it still is not rendering at speeds I believe it should be capable of. Any tips to speed things up? The following are my computer specs:
    h9-1420t Intel
    • Windows 8 64
    • 3rd Generation Intel(R) Core(TM) i7-3770 quad-core processor [3.4GHz, 8MB Shared Cache]
    • 3GB Nvidia GeForce GT640 [DVI, HDMI and VGA via adapter]
    • 16GB DDR3-1600MHz SDRAM [2 DIMMs]
    • 2TB 7200RPM SATA RAID 5 (3 x 1TB HDD)
    • No secondary hard drive
    Here are some things I’ve tried for speeding this up:
    -I keep my source footage on a second partition of my internal hard drive
    -I have enabled multiprocessing in AE and toyed around with how much ram to allocate to each core
    -I have tried using shift to deactivate the previews during rendering
    -I’ve disabled the video thumbnail in the project media window
    -I never run any other applications when rendering
    -I have enabled GPU processing
    Can anyone think of something else, or do you see any obvious mistakes I’m making??
    Todd Kopriva replied 13 years, 7 months ago 4 Members · 5 Replies
  • Todd Kopriva
    February 12, 2013 at 5:24 am
    See this page for resources about making Adobe Premiere Pro and After Effects work faster: https://adobe.ly/eV2zE7
    After Effects team blog
  • Rebecca Loche
    February 12, 2013 at 12:53 pm
    hmmm
  • Marina Leontopoulos
    February 12, 2013 at 4:55 pm
    At first you should take a look at the task manager. Is the CPU working at 100%? How much RAM (physical) is being used? Did you try out a SSD?
    And also important: What components did your old computer have?
    I moved from an Intel Q9550 with 8GB RAM to an Intel i7 3770K with 32GB RAM and it really made a huge difference…
    Rina
  • Shane Sackett
    February 15, 2013 at 7:56 pm
    The cpu is running at 100% but only about 15% of my ram is being used. My old computer was simply just a standard 2011 Macbook Pro i7 with 16gb of ram.
  • Todd Kopriva
    February 15, 2013 at 8:00 pm
    Don’t think that you need to see all of your RAM used all of the time. If the CPUs are at 100% and the RAM usage is at 15%, then this just happens to be a rendering task that is not RAM-intensive.
    Follow the link that I provided earlier, and read/watch the resources that it points to. For example, this video introduces the idea of bottlenecks in processing, which is relevant to what I just said above:
    https://www.video2brain.com/en/lessons/overview-of-data-flow-and-common-bottlenecks
