Activity Forums Adobe Premiere Pro Faster Freeze frames
  • Faster Freeze frames
    Posted by Joseph Mastantuono on September 30, 2011 at 6:25 pm
    Hey, I tried the “Hold Frame” function as an alternate to get a quick freeze frame, but it looks still scrubbing in the timeline, but just plays the clip instead of the frame I want to hold when I press play.
    I would be fine using “export still frame” but that doesn’t automatically import it into the project, so I have to go to the finder, find it, and then bring it back into the project. is there a faster was of handling freeze frames?
    It seems really clunky from the old “Shift-N” that auto brings a still into the viewer from FCP.
    Joseph Mastantuono
    http://www.goodpost.net
    Color Grading & Post Production Consulting
    Ann Bens replied 14 years, 11 months ago 2 Members · 1 Reply
  • Ann Bens
    September 30, 2011 at 8:50 pm
    Add still to project used to be in Premiere, i mis it too.
    Please file a feature request.
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    For the freeze frame. If its the first of last frame you want to freeze i cut the first or last frame off and strecht it with the strecht tool to the desired lenght.
    If its a frame in the middle i use the same technique as describe before. I cut the clip.
    Or you can place an unnummered marker and use Frame Hold.
    Adobe Certified Expert Premiere Pro
