Activity › Forums › Adobe Premiere Pro › Faster alternatives to manually inserting audio volume keyframes in order to reduce dynamic range?
  • Faster alternatives to manually inserting audio volume keyframes in order to reduce dynamic range?
    Posted by Harvey Lester on September 8, 2014 at 2:18 pm
    Hi all,
    I have a whole bunch of audio monologue clips in my Adobe Premiere Pro CS4 project, all with varying amplitudes and dynamic ranges. Up until now, I have been manually adjusting the audio gain of each clip, as well as manually inserting volume keyframes to raise the quieter parts/lower the louder parts, so that during playback, the entire monologue has the same volume (around -2dB) and the lowest possible dynamic range without sounding too “unnatural”. My goal is make the volume of the entire voice track consistent, so that it can be heard clearly over the background music track. In other words, so that the quieter parts are raised to -2dB and the louder parts are lowered to -2dB, with a very low dynamic range
    Are there any faster, more automated ways of doing this that will save me a hell of a lot of the time it takes to manually achieve my desired effect using keyframes? I have just discovered the ‘dynamics’ Premiere Pro CS4 effect, but I’m not entirely sure how to use it. I have a basic understanding of what compressors/limiters to, but some expert guidance would be much appreciated.
    Thanks in advance!
    Harvey Lester replied 12 years ago 3 Members · 4 Replies
  • Harvey Lester
    September 8, 2014 at 2:52 pm
    I should add, I also have Audition CS5.5 and Soundbooth CS4…
  • Steve Brame
    September 8, 2014 at 3:33 pm
    Didn’t(or doesn’t) Soundbooth have a “Volume Leveler”?
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Alex Udell
    September 9, 2014 at 10:30 am
    This could be tackled in Ppro or Audition.
    Dynamic Range “Compressors” are available in both.
    in PPro if you can get the clips on to the same track, you can apply it as a track effect in the sequence audio mixer.
    Take a look at this background wiki for info:
    https://en.wikipedia.org/wiki/Dynamic_range_compression
    this would get you in the right ball park…and then you’d beed a lot less keyframes….
    hth,
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Harvey Lester
    September 9, 2014 at 10:41 am
    Thanks for the replies guys. I managed to work it out on my own in the end. I exported the entire track out of PP as a .wav file, imported it into Audition, then used the single band compressor to level out the volume/reduce the dynamic range to my required settings. I’m very pleased that I won’t ever be burdered with the laborious, time consuming, tedious task of achieving the same outcome manually with keyframes ever again!
