Activity Forums Apple Final Cut Pro Fast way to set all keyframes for Transform, Crop and maybe Distort as well?
  • Fast way to set all keyframes for Transform, Crop and maybe Distort as well?
    Posted by Brian Thomas on August 15, 2016 at 4:01 pm
    I’m animating some photos and doing a lot of clicking on the keyframes for Position, Rotation, Scale, all the way down to Crop/Bottom and sometimes all the Distort positions. That’s a lot of clicking. Is there perhaps a single keystroke (or not much more) that will for all of these things set all the keyframes at the current position? I’ve done all Larry’s and Izzy’s tutorials but some time ago and I’m hoping I’ve simply forgotten what’s involved. Many thanks in advance.
    FCPX and PPro 6. iMac 24 + MBP 15″. Near Geneva, Switzerland
    Brian Thomas replied 10 years ago 3 Members · 5 Replies
  • Bret Williams
    August 15, 2016 at 7:15 pm
    I think if you just do it all in the viewer window and click the Keyframe button there it will take care of it. I don’t usually click the Keyframes in the inspector.
    _______________________________________________________________________
    https://BretFX.com Plugins & Templates for FCP X Editors & Motion Graphics Artists
  • Brian Thomas
    August 15, 2016 at 9:27 pm
    Thanks for that Bret and it certainly helps. I see now that by doing it the way you suggest I can set all keyframes for EITHER the Transform OR Crop set of attributes but not both at the same time. In any case that’s going to save me a lot of clicks! Thanks again.
  • Bret Williams
    August 17, 2016 at 10:34 pm
    There is a distort tool. Not sure I’ve key framed that before.
  • Robin S. kurz
    August 23, 2016 at 12:45 pm
    If the animation is always the same, you can of course simply use the Copy and Paste Attributes commands. Even if just the timing is roughly the same you could use it and simply tweak the keyframes individually as needed, but at least you wouldn’t have to set/activate them first.
    – RK
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Brian Thomas
    August 23, 2016 at 12:55 pm
    Thanks Bret and Robin. I was aware of the copy and paste of keyframes and it is SO useful. In this case I was overlaying video of a presenter with the material he was presenting and then using (mainly) the Transform keyframes to zoom in and move around. It came out great! Regards.
