Activity Forums Avid Media Composer Fast way to create new user and site settings in Media Composer
  • Fast way to create new user and site settings in Media Composer
    Posted by Peter Slabysz on February 24, 2021 at 7:48 pm
    I’m excited to upgrade the version on MC. However, as usual, all the settings have to done again from scratch, as far as I’ve been told. I was going to screen grabbing everything. But it is a royal pain trying to remember what all the two-letter abbrev. stand for in the keyboard mapping and I have a bunch of site settings. Any faster, easier way?
    Alan Chimenti replied 5 years, 6 months ago 2 Members · 1 Reply
  • Alan Chimenti
    February 25, 2021 at 7:27 pm
    Peter –
    Faster/easier way is to create a new user (as you’re doing.) If you open the Settings window (command + =) and then Open Settings File (command + O) you’ll be given the option to open a Setting or Preferences File. Navigate to your existing User file (for your earlier version of MC) and select the Settings.xml. This will open up a separate window with your old (existing) settings file from which you can drag and drop individual settings that you have already created into your new User Settings tab. I believe you’ll be given the option to “Add” individual user settings the new settings, or “Replace” the new settings w/ old ones. You’ll probably want to mix-and-match at this point. But pre-set Export / Workspaces / Timeline / Keyboard settings – pretty much all set-ups – can be quickly and easily ported over to new base MC settings.
    Hope that helps.
    – AC
