Activity Forums VEGAS Pro Fast Start audio problem/Vegasaur ?
  • Fast Start audio problem/Vegasaur ?
    Posted by Mike Hinkel on June 29, 2011 at 2:22 am
    I’m using Fast Start to move the metadata for uploading to YouTube. The render on file is fine, but when playing it back on YouTube there are pieces of the audio rhat are garbled or missing altogether. It doesn’t seem to matter what audio file I use.
    Is there away to use the Vegasaur YouTube tool without having to render right to YouTube right off the get go. I’d like to see the results before uploading. Maybe someone can show me steps to take with tha utility. Thanks
    Mike Hinkel replied 15 years, 2 months ago 3 Members · 5 Replies
  • Nigel O’neill
    June 29, 2011 at 3:31 am
    I was able to easily render to a file destined for Youtube using Vegasuar recently. Someone else eventually did the upload as I didn’t have a Youtube account.
    I don’t have screenshots as I believe it was as simple as deselecting the Upload check box and following the prompts that follow… .
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Aleksey Tarasov
    June 29, 2011 at 4:32 am
    Unselect the Upload button if you want to disable the upload function.
    Click on the question icon in the upper right corner of the window to open the help file, where you can find instructions.
  • Mike Hinkel
    June 29, 2011 at 6:29 pm
    Thanks guys. I got it figured out. The problem I still have is that Vegausaur uses the same mp4.Fast Start program I have audio problems with once uploaded to you tube. Does anyone know if there another tool to move the metadata to the front of the file?
  • Aleksey Tarasov
    June 29, 2011 at 7:00 pm
    What tool do you use? Video4Youtube uses mp4box
  • Mike Hinkel
    June 29, 2011 at 8:03 pm
    Aleksey, It appears I downloaded the wrong tool from the Vegasaur redirect. I’ll have to catch up to the right tool and see how that works for me. Thanks for the help.
