Activity › Forums › Adobe Photoshop › Fast scanner with dust & scratch removal
Posted by Morris O. on November 22, 2005 at 12:57 pmLooking for a FAST scanner with good dust & scratch removal that will work on regular photos. Any suggestions?
Thanks.
Morris O. replied 20 years, 10 months ago 3 Members · 3 Replies -
Richard Harrington
November 22, 2005 at 1:22 pmIf you want fast, look to Firewire connection (over USB2)… but you shoudl give your price range when looking for recommednations
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.comedit – produce – direct –
Del Holford
November 22, 2005 at 4:02 pmWhile Richard pointed out you didn’t state a price range, if you can go the freight the Epson Expression 1680 is an excellent scanner. It has a negative/positive slide adapter with it and works with SilverFast scanning software plug-ins for Photoshop. It can orient the picture anyway you want and has several settings for dust and scratch removal and various settings for scanning the object up to 16 times to get the best scans. The price on CNET’s Shopper.com is around $1K for the pro version.
HTH
Del -
Morris O.
November 22, 2005 at 8:22 pmThanks Richard & Dell,
My price range is below $500 but below $300 would be better.
Morris
