Activity Forums Adobe After Effects Fast image sequence
  • Fast image sequence
    Posted by Alberto Bedin on March 31, 2012 at 9:07 am
    Hi all,
    I searched for it in Google but I didn’t find anything…
    I would like to create a fast sequence of still images (photos), every image should last on the screen a bit of frames.
    As an example think about the intro of The Big Bang Theory sit com but without the zoom effect.
    The images should linearly increase their speed (last a minor number of frames) while moving to the end of the sequence.
    The sequence should have a lot of images (maybe more the 100) so I can’t think about manually add them.
    How can I achieve this result? Maybe using an expression? Some other trick?
    Thank you
    Alberto Bedin replied 14 years, 5 months ago 2 Members · 3 Replies
  • Alberto Bedin
    March 31, 2012 at 7:30 pm
    Ok thank you, I will do it frame by frame. 😛
    However maybe I could start from all images of the same duration (let’s say 2-3 frames each one).
    How can I import a lot of images (100?) and place them in a composition in which each image lasts 2-3 frames?
    Maybe can I set a default length for still images and then mass move them into a new comp?
  • Tero Ahlfors
    April 1, 2012 at 4:46 pm
    Set the preferences to import still images to your liking. Then add all pictures in a comp. Select all -> right click -> keyframe assistant -> sequence layers.
  • Alberto Bedin
    April 1, 2012 at 10:01 pm
    I have used another solution that worked very well:
    1) import the images as a sequence footage. Now every image lasts 1 frame.
    2) Use time stretching and/or time remapping to increase the duration of some images.
    You can eventually insert your sequence more than once in a composition, changing the time stretching. As stretching value, use multiple of 100%. So if you set 300%, every image will last 3 frames.
